Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 214 Registered: Jul-04 | I am going to buy 4" Aeroports! How long do those come? and they are lipped twice? Why is that? |
Gold Member Username: RovinTrinidad & T... Post Number: 1557 Registered: Jul-05 | Did u check your tuning - 4" ends up being kinda long & u should check the depth of your box to see if it'll fit . use the tuning calculators @ www.the12volt.com Fusion audio & Lightening audio sell these so check out their websites ... |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 217 Registered: Jul-04 | Ya I am going to use them with 2 12" Fusion Powerplants! Well on www.bcae1.com the depth was fine with a 4" diameter port! |
