Samsung DLP- overheat message
Username: Sesteinberg
I have a 2 year old HLN507w. First bulb lasted 18 months. 6 months into the second bulb set would turn on but bulb would not fire up; unplug retry eventually would start. Now it gives an actual message on the screen saying that there is an overheat problem--clear vents, move heat generating components etc... I've let it cool down, unplugged etc. Put a small room fan on it etc. --the fan near the bulb is spinning. Always the same message. Any suggestions? thanks
Username: Fyi
Dallas, Texas
Post Number: 866
Try replacing the lamp fan. Just because it spins doesn't mean it's up to speed. Other than that, a service call to 1-800-SAMSUNG. If you are persistent they may work with you.
These are new inventions. Yours is only a second generation. Extended warranties are always a good idea. Good luck!
