Audiobahn or Hifonics
Username: 2loud4u
Boca Raton, FL U.S
Post Number: 47
Hey I don't know what to do in this situation. I either want the new 2005 Hifonics Collossus which is 3200 rms (b/s). Or the Audiobahn a4kdn which is 4000 rms (b/s). The Audiobahn is a few hundred more but it has more power. It is being used to push an 18" RE MT. Any input is appriciated. Thanks.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1294
personnally...i would take the Collossus.
Username: Nocc1n
Louisa, VA US
Post Number: 54
Yeah I would take the Hifonics myself.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 1058
Yea. Hifonics...
Username: Avalanche
Post Number: 143
Hifonics here also.
Username: Tdisanto
Post Number: 423
speaking of poltics, def go Hifonics;lol
Username: Carguy
Post Number: 4737
If you like your RE 18" MT, try a better quality amp.
Username: Carguy
Post Number: 4738
I don't know if you purchased your sub new or not, but 18" is around $470 - $500. Why would you cut corners by getting a cheap amp?
Doesn't really make sense to me. That would almost be like buying a Porsche and using $3 regular motor oil.
Username: 2loud4u
Boca Raton, FL U.S
Post Number: 48
Hifonics It is!
Username: Jake110011
Jackson, Michigan
HIFONICS!!!!!!!!!! YEA definantly
Username: Comp98
Philadelphia, PA USA
Post Number: 134
Listen to Issac. I wouldn't put $3 dollar motor oil in my porsche any day.... too bad I have an accord. : /
Username: Alexv305
Tavernier, FL USA
Post Number: 25
HIFONICS is da bomb
Username: Basshead86
Ocala, FL USA
Post Number: 2457
hifonics sux.
but in this case, it is a little better imo, than audiobahn.:-)
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 490
if u can afford that audiobum try and find something with a tad bit more TRUE power (as stated above)
