Help with 4 channel amp wiring to 2, dual 2ohm subs
Username: Dodgeviper101
hi, i have just bought as a package, 2 jbl GTO 1202D which are dvc 2 ohms, and a jbl GTO 75.4 amp. i have no idea how to connect these to get the best bass out of my subs, could some one please help me
Username: Rovin
Trinidad & T...
Post Number: 1460
this is what u got right ?
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO1220D&cat=SUB&ser=GT S
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO75.4&cat=AMP&ser=GTS
i'd say use that 4 channel amp for your door speakers & buy a mono for your subs
ok then, but which jbl mono amp should i go for?
Username: Nocc1n
US
Post Number: 113
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO601.1&cat=AMP&ser=GT S
get that one, wire each subs voice coils in series to get a 4 ohm load from each one, then wire each sub in parallel to get a 2 ohm load, you would be set.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10802
bridge the amp to 2 channels
wire sub coils in series
put one sub on each amp channel
cheers guys, i am sellin the amp on ebay and will go for the jbl gto 601.1 mono amp once i get the money and see how that goes.
