Good head unit
Username: Markd
UK
hi, i know this is a rather general question to ask, but which makes of head unit are the best. the type of head unit i require should have:
2 or more pre outs
high and low pass filters
parametric eq
mp3 playback
i'm not fussy what brand i use, as long as it sounds nice. i'd like a unit that doesn't shape the sound when the eq is set to flat. the kenwood unit i have at the moment has poor sound quality, its only a few months old and has sounded like that since i bought it. i'm looking for a unit that has really high sound quality. i'm not bothered how powerful it is, ideally i'd like a unit that doesn't even have an on board amp! i'm going to use a separate amp for my speakers, and another for my subs. so the on board amp is useless. what i really want is a clean signal going to the amps, but don't know what makes are the best for sq. any info would be appreciated.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2095
Alpine CDA-9835
http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=CDA-9835&p_category=10 &p_subcategory=20&p_main=10
disable the internal Vdrive amp for best signal quality.
it's turned off completely via the setup menus.
