Alpine Type R's
Username: Chimera87
i'm thinking of buying a pair of alpine type r's, prolly 12". but before i do i just wanna know a bit more about a couple terms. would it be better for me if i bought subs that were svc or dvc? why? and does a higher ohm rating=better sound or the other way around??
Username: Audiobass10
Cape Coral, FL United States
Post Number: 305
The sub's impedance has nothing to do with performance. It simply has to do with different wiring options.
Username: Jakeyplaysbass
Post Number: 101
i think the type Rs only come in dual 2 or 4 ohm. If you have an amp that puts out 1000 watts at 1ohm get two dual 4ohm subs. if it puts out 1000watts at 2ohm get two dual 2ohm subs.
Username: Rovin
Trinidad & T...
Post Number: 1509
Jake is totally right
