Cs 4000 plus files
Username: Nikon20
can anyone please help me find the factory flash files for the cs 4000 plus i was told i need to jtag it the problem it it turns on and after a few seconds it resets itself like it is a boot/power problem anyway the only files i can find are the cs 4000 por files and i need the cs 4000 plus files so any help would be great and if anyone has any ideas that might help please let me know do you think jtaging it will fix it and can the jtag mess it up any more as you can see im a newbie lol thanks for your help.
Username: Max5wm
Post Number: 73
Does not sound like j-tag to me. Sounds like you have a bad connection either to the wrong input or a bad wire grounding out. Possibly, or a bad channel list.
Username: H3lt3r_sk3lt3r
Post Number: 35
@ryan wilson
Jtaging should be your last resort, like MAX Power said, it sounds like a bad connection check the coax coming in to your box, as well as the connection going into the lnb.
Username: Thill1951akalk
Post Number: 185
go to www.al7bar.tk...FTA receivers ...co*olsat area...best co*
olsat info on the net is there..
Username: Spank
Post Number: 60
http://www.coolsatusa.com/support.htm
Username: Nikon20
i can turn it on and the tv comes on but after a few seconds it reboots itself like the power was turned off then back on and it repetes itself
Post Number: 206
====HELP MY CO*OLSAT IS REBOOTING/LOCKING====
-You may have a bad channel list. Try loading a different list.
You may also need to load a channel list specific to your lnb. see http://forums.al7bar.tk/forumdisplay.php?f=181
-There are some bad channel lists floating around out there.
For example: http://forums.al7bar.tk/showthread.php?t=59663
has a bad channel list.
-Be sure to double check transponders/channels for anomalies if importing channel lists from other formats (gtools, channel master).
http://forums.al7bar.tk/showthread.php?t=64400
-If the problem persists, turn off the power unhook the lnb cable to the receiver, then power up the receiver, open the menu and wait to see if the unit is still locking. If so you may have a bad receiver.
reflash the factory bin then 134 and it sould solve the prob...... then next time u change the bin, delete all chs and do a factory reset to clear out all the crap....
