Username: Shadylimitedx Pgh,
Pa
Usa
Post Number: 338 Registered: Apr-05
Tuesday, October 18, 2005 - 22:43 GMT ok i just put other sub in my box is it goin 2 b louder than just the 1. i have 1 facin the tail lights an the other 1 on top of the box facin the rear deck upward will it b louder than just the 1 facin the trunk they r 2 12 volfenhags 1 wit a kennwood 600W @ 8ohms an the other is 1 wit a pioneer 760W @8ohms an the box is tuned @ 28hz
Username: Caraudio Toronto,
Ontario
Post Number: 315 Registered: Sep-05
Tuesday, October 18, 2005 - 22:58 GMT Face both towards the lights id say. I dont know about 2 box or one box if it iwill be louder depends on box specs etc.
Pa
Usa
Post Number: 339 Registered: Apr-05
Tuesday, October 18, 2005 - 23:10 GMT trunks 2 small so i had 2 do 2 subs in 1 box casue 2 boxes dont fit
Pa
Usa
Post Number: 343 Registered: Apr-05
Tuesday, October 18, 2005 - 23:32 GMT
Username: Loc_out Post Number: 279 Registered: Feb-05
Tuesday, October 18, 2005 - 23:47 GMT what the fu*k!!!!!!!!!!!! you got to be kidding me!
Username: Jakeyplaysbass Post Number: 95 Registered: Jul-05
Tuesday, October 18, 2005 - 23:50 GMT its most likely going to sound really bad like that. you need to have them facing the same way.
Pa
Usa
Post Number: 345 Registered: Apr-05
Tuesday, October 18, 2005 - 23:59 GMT magnet in the way i was bord so i tryed 2 lol this is what it used 2 look liek its loud as he11 tho
Pa
Usa
Post Number: 346 Registered: Apr-05
Wednesday, October 19, 2005 - 00:01 GMT this is my ghetto system 4 now ill b gettin my new 1 after i get all my stuff done 4 my car
Pa
Usa
Post Number: 347 Registered: Apr-05
Wednesday, October 19, 2005 - 00:06 GMT here my bois trunk i did all in green an gold crushed velvet its not done but heres a pic
Username: Araknid BOCA ,
FL
U.S.
Post Number: 1094 Registered: Nov-04
Wednesday, October 19, 2005 - 00:09 GMT hmmmmm well all I can say is make sure there not out of phase.....
Pa
Usa
Post Number: 349 Registered: Apr-05
Wednesday, October 19, 2005 - 00:14 GMT what u mean
FL
U.S.
Post Number: 1095 Registered: Nov-04
Wednesday, October 19, 2005 - 00:18 GMT well as long as you have them hooked up pos neg - pos neg for both they should be in phase.
Username: Rovin Trinidad & T...
Post Number: 1470 Registered: Jul-05
Wednesday, October 19, 2005 - 00:42 GMT U are a weird 1 Scott ! - lol 1st that crazy 2 sub @ right angle thing & then that couch fabric covering thingy ..... Use reg speaker box carpet ,man or even some granite printed laminate pattern or formaica if u want to be different .
Pa
Usa
Post Number: 350 Registered: Apr-05
Wednesday, October 19, 2005 - 00:47 GMT its my friends he wanted crushed velvet
