WHERE IS THE GAIN ON A AMPLIFIER???
i have a audiobahn A8002T and all of you guys talk about messing with the gain on the amp...
where is this on the amp??
and why do you use it?
thanks
Username: Tdisanto
Post Number: 469
It should be on the side of the amp where all the other controls are.
Its used to match the pre-out voltage on the head unit to the input section of the amplifier. Its also known as a sensitivity adjustment.
www.bcae1.com for more info.
Username: Dustin3
Tigard, Or U.S.
Post Number: 47
on my amp the audiobahn A8002T where would it be??? Is it a knob that you can turn? i cant find it...
Username: Rideredder
Cornell, IL USA
Post Number: 73
Is there a hole with a thing inside that looks like you could turn it with a small screwdriver? It should say gain or something by it.
Username: Tdisanto
Post Number: 471
I havent had any personal experience with any audiobahn amps (theres a reason for this, lol) but all amps have a gain.
On that note, it should be a dial and it SHOULD be labeled. There might also be like 0-5V or something like that around the dial as well.
