New member Username: InvictivePost Number: 1 Registered: Oct-05 | I have a box with 3 speakers in it wired in parallel. I dont know how many ohms the speakers are rated at, it doesnt say anywhere on them. It is a Thump TBB 103 box. I am guessing I need an amp that supports 2 ohms bridged mono? Or maybe 1? I also have a Pyle PLA2280 amp that I would like to use if possible, but it only supports 4 ohms brdiged or 2 ohms stereo. Can anyone tell me what impendance I will need, or how to find out what the impedance of the speakers is? Thanks |
Gold Member Username: RovinTrinidad & T... Post Number: 1417 Registered: Jul-05 | use this http://www.the12volt.com/caraudio/woofer_configurations.asp |
New member Username: InvictivePost Number: 2 Registered: Oct-05 | how do i find out the impedance of my speakers, its not printed on the speakers and i cant find it anywhere online, the company seems to be out of business. they are thump tbb 103 |
Gold Member Username: James1115Wilton, Ct Post Number: 4093 Registered: Dec-04 | pull the sub out of the box it should be on the magnet. Those subs are old I havnt seen thumps in about 8 years. |
