RCA universal adapter
Username: Hailgalvatron
what exactlly is this. it says you plug it into your cigarette light and it comes with all these adapters. Would you be able to play your ipod through this?
Username: Comp98
Philadelphia, PA USA
Post Number: 116
I think it's just a power adaptor......plug it into your cig lighter and it can power different electronics e.g. portable radios, small televisions, cd players, that kind of thing. It wont do anything else except give power to electronics.
ps. I think the max power is 12v though.
Username: Xkawn
Post Number: 197
that won't be able to hook up to an ipod at all. the charging system for the ipod is through the usb adapter and i doubt that has usb on it. plus like comp said, it's just for power. theres no link between that and your stereo.
