No memoryy
hey i just installed a pioneer pm-36000 head unit in my firebird. Everything thing seems to be order, but i get no memory functions. everytime the car turns off i lose everything and when i turn the car on the unit has to be turned on via source button. Whats my problem here!
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1886
your constant/memory wire on teh ehad unit isn't wired properly.
it's probably wired to teh ignition line.
lou
where do i wire the constant to? the battery?
Username: Glasswolf
Post Number: 1919
there's a constant +12V line behind the head unit from the factory harness.
if you used a wiring harness kit, the wires are labeled, and nothing should need to be cut.
