Jl audio xr650 comps vs. infinity perfects???
Username: Skyliner17
Saint Paul, MN United States
Post Number: 184
i have the perfects right now but am looking for a more natural sound. perfects are just too bright esp. with some female voices... would the jl audio be a good set? would it be a step up from perfects??? any input appreciated
Username: Tdisanto
Post Number: 255
They are a step up from the perfects, there hand made in germany. Anyhow, as far as brightness is concerned i dont know how they compare to the infiniys but im sure its not as bright(i havent heard the JLs before)
This is what jonathan posted about the Xr
JLs aren't designed for average installations. Shallow slope x-overs and a rather high x-over freq. for a 6.5" mid. Needs a kick panel install or angled door to get best results. If you don't, they won't sound good because the drivers won't mesh well. The majority of people that are dissatisfied with any component system are the ones that didn't take the time to install them correctly. Install= 70%+ of the end result.
Username: Spyder
Eglin AFB, Florida USA
Post Number: 128
I have the Xr's installed in my car.....i have ran the Perfects before......To be honest if you install them and image them right they will outdo the perfects hands down.......but get all the info on installing them first!!
Post Number: 185
are the Xr's as bright as Perfects? how would i image them in my 95 accord? right now i have my perfects woofer in stock and tweeters, have them flush mounted on the door kinda like in a civic. any ideas on how i would image the Xr's??
Username: Spyder
Post Number: 131
i think the best thing would be kick panel's......installing components isn't really physically hard......but i can say it's an art that i can fully say i haven't mastered just yet.....but idealy you want the left speaker to aimed at the the right headrest....and the right aimed at the left headrest!!
Username: Brandonk17
Post Number: 33
I know this wasnt my question... but simon can you elaborate a little more on imaging... like should it be aimed at the headrest from the position the seat is usually in or from a postion that is all they way back/forward?... also ive heard of laser pointers being used to get the imaging lined up... is this a good way to go?
sorry for posting in the middle of thread vincent
Username: Tdisanto
Post Number: 286
Yes, i have heard of people using laser pointers to aim the position of the tweeters.
lol...
Username: Spyder
Post Number: 134
you can use the laser pointers but i know nothing on how to use them.......you want the seats in the normal positions they will be in for when you drive the car........and don't do like i did....i put my crossover in the door behind the paneling.....hooked em up and tuned the amp.....with out setting the crossover up for less treble and what not!!!!
Post Number: 35
i see... well thanx for the response... im going to post it in a different thread cause i feel bad for hijacking this one... so if anyone wants to know more about this then go to the other thread... sorry vincent :-)
Post Number: 187
i'm still worried that the jl xr's will be too bright cause of the metal dome tweets. i like them in some of the music i listen too but not all so i think i should look into a set with silk dome tweets. how would the cdt sets or any other with silk dome tweets compare to the infinity perfects??? any inputs...
Post Number: 188
i meant sound wise. i want clarity with tweets that will sound loud but not be too bright where they hurt your ears. do u guys know what i mean...
Username: Ologyaudio
Columbus, Oh USA
Post Number: 28
check out the tech discussion at the end of this thread:
https://www.ecoustics.com/electronics/forum/car-audio/167668.html
That being said... the Dayton RS tweeter is exceptionaly smooth -- and the seas TBFC is very nice (airy as hell though thats for sure)
You would be hard pressed to find a quality metal dome in the car audio scene -- aside from say the seas lotus... BA Z's tweeter is pretty decent btw...
