New member Username: Estilo_806Plainview, Texas U.S. Post Number: 4 Registered: Oct-05 | What does mono and bridged mean is there a diiference I see alot of amps that say 200watts at 4ohm bridged or 400watts at 2ohm mono what the heck does that mean someone please let me know. |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1252 Registered: May-05 | "mono" means one. "bridged" mono means combining 2channels to make one (mono). |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10762 Registered: Dec-03 | a mono amp is a single channel amplifier. it tan accept left and right RCA cables as input but the output signal is a combination of both L+R as a single output bridging an amp is a method of taking a 2 channel or four channel amp and combining two channels into one to put all of the power of two channels into one speaker or one load. |
Silver Member Username: TdbdadrummerPost Number: 549 Registered: Aug-05 | Bridging...increases heat products and distortion levels on the downside, and generally should be avoided. |
New member Username: Estilo_806Plainview, Texas U.S. Post Number: 5 Registered: Oct-05 | Ok thanks guys for all the help. |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10768 Registered: Dec-03 | umm, bridging an amp just puts the same power into one channel at 4 ohms as it would into two channels at 2 ohms. distortion and heat will be the same. man there's a lot of misinformation floating around about car audio. Sometimes it's hard for anyone to get a clear answer about something it seems. here's some very specific information on bridging an amplifier, and exactly how it works: http://www.bcae1.com/bridging.htm |
