Getting Alpine amp out of "SAFE MODE" ??
Quagmire
Anyone know how to get an Alpine MRD-301 amp. out of safe mode? The manual tells me nada. Thanks.
Quag mire
giggidy giggidy
Username: Tdbdadrummer
Post Number: 427
Safe mode lol, sounds like a computer problem...
Quagmire
haha, true, thats what i've heard it referred to as, maybe its "power save mode" ?
Username: Moondog1212
New York United States
lol. It's "protect mode" if it is always like that, you might have a bad ground to your amp.
other than that not sure what to tell you.
Username: Pikesh
Toronto, ONtario Canada
Post Number: 238
nope.... sometimes when u install the amp and run it for sometimes... the amp wouldnt give you ne sound becaouse of safe mode.. it will turn on but no sound.. to do this u neeed to look at manual... it HAS to say about it.... or it should hae something on the amp itself in terms of options n how to use.. soo try that if not mention the model number of amp here n may be i can help further
