Difference in amps to power subs
Username: Iufan4lifeul
Post Number: 524
Ok, so honestly. When it all comes down to it what is the difference in these things. Like most people say, the distortion is never an issue on these amps. Now, I am not going to compare a Pyramid with an Orion but if say, for example you run a 1200rms Orion vs. the Kicker 1200.1 what would be the audible difference between the 2? I realize that the difference might be heard if you were powering speakers with it, but with subwoofers could you TRULY tell the difference?
Username: Taylor17
Kopperl, Texas
Post Number: 3114
Personally, I don't really think so, but never really compared.
I guess the THD numbers might give you an idea.
Username: Basshead86
Ocala, FL USA
Post Number: 2215
i would say damping has a little more to do with SQ than how much less of a fraction of a percent you can get your THD.:-)
Username: Taylor17
Kopperl, Texas
Post Number: 3116
Yeah, good point.
I'm not in to amps as much... I know just enough.:-)
Ocala, FL USA
Post Number: 2217
i wasn't arguing with you, just adding to the cause.
i read somewhere that up to 10% THD is inaudible in a car environment(road and engine noise). but i could be wrong.
Username: Taylor17
Kopperl, Texas
Post Number: 3118
Lol, I didn't think you were... but it wouldn't supprise me if thats true.
I could see how you might be able to tell on tweeters or speakers... but on subs, I find it harder to believe an amp can make an sq difference.
I'm prob showing some of my lack of knologe about amps by saying that.
Ocala, FL USA
Post Number: 2218
nope, check this out.
http://www.bcae1.com/thd.htm
Username: Taylor17
Kopperl, Texas
Post Number: 3120
Well, you were right.
THD has a little part in it, but not that much over all.
Ocala, FL USA
Post Number: 2228
did you change your username?
Username: Taylor17
Kopperl, Texas
Post Number: 3128
Lol yeah... just now noticed?:-)
Username: Keith78
Post Number: 25
ive been looking for that info for days man do i appreciate it
Username: Tdisanto
Post Number: 387
damping factor plays a much bigger role than THD + noise. It directly effects sound quality bc it reflects how much control the amp has over the driver.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1205
actually, damping factor is very overrated. if the number is over 30, you won't tell a difference. thd, s/n, power supply, all very important.
thread for thought i dug up as a muzzle on another thread. http://caraudiomag.com/specialfeatures/0111cae_anatomy/
Post Number: 525
according to this site (http://www.soundsolutionsaudio.com/forum/lofiversion/index.php/t3103.html) dampening factors can get over the couple hundreds. My kicker 450.2 is rated at 250 or so according to them. That ain't bad.
Username: Mikechec9
Post Number: 1209
yeah. the average is 100-200. but that's the thing. so long as it's above 30, you are not likely to notice a difference.
Ocala, FL USA
Post Number: 2235
he's right, it states that on bcae1.
but i would rather have a damping factor of 200 and a thd of 1% than a damp of 30 and a THD of .0000000000000000000000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000001%.:-O lol
Username: Taylor17
Kopperl, Texas
Post Number: 3138
Lol... was all that needed?:-) So is a THD rating of 1% better or worse than THD of 0.05%... because I've always thought the lower the number... the less distortion.
Ocala, FL USA
Post Number: 2240
yes, the lower the number the less distortion, but did you read that link i posted?
Ocala, FL USA
Post Number: 2241
here, i'll show ya.
"Many people believe that THD below 1% is not audible and I believe they're probably correct. The fact is, especially in an automobile, the amplifier is the least of your worries. Speakers used for mids and highs commonly produce between 1% an 5% THD and for subwoofers the numbers can easily reach 10%. This doesn't even take into account all of the resonances of all of the plastic and metal panels in the vehicle."
understand?
Ocala, FL USA
Post Number: 2242
there are so many other noises in a car, that a THD of 1% or lower really isn't an issue.
unless you listen to your music in the middle of a field, with the windows up and just the battery powering everything. lol
Username: Taylor17
Kopperl, Texas
Post Number: 3142
Actually, I do.
You may not be able to tell a difference from just 1%, but when looking for a good amp, you would want the one with the lowest THD, and the highest dampening factor right?
Ocala, FL USA
Post Number: 2249
something like that. lol
if your not sure, ask us! LMAO
