New member Username: Eddyg519Post Number: 3 Registered: Oct-05 | I was thinking of getting some woofers off ebay (powerseller with great ratings), is that a good idea? Also will Six VOLFENHAG ZX-4712 DVX 12" (500watt RMS each) pound with extream force? :P Because its in my budget...also what kinda Amps do i need to power these bad boys and do i need a second battery? Thanks in advance! - Eddy |
Gold Member Username: James1115Wilton, Ct Post Number: 3969 Registered: Dec-04 | if he is a power seller then I would say it is fine. I buy things off of ebay all the time. I would not personally go with the VOLFENHAG's but that is me. You would get much better performance by a couple of better subs powered correctly then by six bad,unreliable subs. As far as what you would need to power them according to the specs you posted you would need 3000 watts which to answer your last ? about needing a second battery the answer would be no unless you were going to be cranking your stereo with your car off. What you do need is a very very hefty alternator upgrade because no stock alternator could handle anywhere near that amount of power. How much are the subs you are looking for on ebay? |
New member Username: Eddyg519Post Number: 4 Registered: Oct-05 | well ive been looking around and the Van's dont seem to be the best ones... im now looking at these : http://cgi.ebay.ca/2-KICKER-S15L7-SOLO-BARIC-15-SUBWOOFERS-NEW-2005-MODEL_W0QQit emZ5817261275QQcategoryZ58035QQtcZphotoQQcmdZViewItem thats 2 15" Kickers = 2000watts RMS Im considering getting a 3rd but i mean is it worth it? It will most likely be played in a hatchback... lol - Eddy |
Gold Member Username: James1115Wilton, Ct Post Number: 3970 Registered: Dec-04 | for $500 you could get 2-RE SX 12's that would sound so much better and be louder then either of the set-ups you have mentioned. When you add more subs into your equasion if you give 2 subs 1000 watts and then add a 3rd so now the subs get 333 watts it will not be any louder. In order for you to make a audible difference you would have to give the third sub the same power as the other subs. So if you have 1000 watts to 2 subs you would need 1500 watts to 3 subs and so on. Also the box you decide to use will make a huge huge difference in how your subs sound. What is your goal? do you want HIGH SPL with no reguards to SQ or do you want a mix of both? what kind of car is this going in? how much is your entire budget? |
Silver Member Username: Audiobass10Cape Coral, FL United States Post Number: 269 Registered: Jul-05 | I wouldnt necessarily say the SX's would be louder than the L7's, but they'll definitely sound a hell of a lot better. Also they're much more of a reliable sub than the L7's. |
Silver Member Username: TdisantoPost Number: 353 Registered: Sep-05 | Either way you go the alternator is going to have to be upgraded. |
Silver Member Username: TdbdadrummerPost Number: 441 Registered: Aug-05 | I think the Volfenhags might even sound better than the L7's :P |
Silver Member Username: Robert_dMIA, FL USA Post Number: 194 Registered: Sep-05 | lol tyler always defending your volfs how do i figure out the amps consumption on a class d mono amp ? well it would just be easier to tell me ... the kx1200.1 thanks i know the kx200.2 will take bout 16 |
Silver Member Username: TdisantoPost Number: 360 Registered: Sep-05 | multiply by 1.2 http://www.wickedcases.com/caraudio/charging.html |
Silver Member Username: TdbdadrummerPost Number: 444 Registered: Aug-05 | Oh...one of these days "A German Concept" will reign supreme LMAO! |
New member Username: Eddyg519Post Number: 5 Registered: Oct-05 | lol thanks for the help guys sorry i dont know alot of sub names but who makes the "RE SX 12's" ? Im basically going to listen to Trance and hiphop (so a mix of SPL and SQ i suppose). - eddy |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2190 Registered: Aug-05 | Resonant Engineering www.reaudio.com |
Bronze Member Username: Eprussian07Post Number: 13 Registered: Oct-05 | RE is Resonant Engineering. You can find their subs at www.reaudio.com If you are looking for a good SPL sub, dont buy the kicker, buy the RE .mt series. If you want a mix, go with the .sx series. Here are some specs for you: Resonant Engineering Pricelist (note prices do not include shipping and handling charges) RE8- $49 RE10- $59 RE12- $69 SE10- $149 SE12- $169 SE15- $199 SX10- $239 SX12- $249 SX15- $269 SX18- $309 XXX10- $359 XXX12- $369 XXX15- $399 XXX18- $429 MT10- $409 MT12- $419 MT15- $449 MT18- $479 there is a $25 charge to upgrade the MT or TripleX line to a quad voice coil configuration. ------------- RE - 175wRMS -- DVC 4 ohm SE - 600wRMS -- DVC 4 ohm SX - 1000wRMS -- DVC 2 ohm XXX - 1600wRMS -- DVC 2 ohm, QVC 2 & 1 available MT - 2500wRMS to 5000wRMS -- DVC .7 & 1.4 ohm, QVC .7 & 1.4 ohm |
New member Username: Eddyg519Post Number: 7 Registered: Oct-05 | so would kicker be a good SQ sub? because my friend is getting a decent system in his truck (s10).. thinking of tossing like 2 10's under the back seats (rasied) and one 12 or 15" in the middle of the 2 seats (if it fits). - Eddy |
