Alex K. Unregistered guest | I have 2 12" Pioneer subs, they are 500 watt each. What wouold be the best amp to give this the best sound they can handle? |
Gold Member Username: RovinTrinidad & T... Post Number: 1150 Registered: Jul-05 | Which model is that - not the 306 model ? |
Alex K. Unregistered guest | Not sure. My cousin had given them to me. They are a couple years old but he didn't have room in his trunk for them. So he installed them and I only have 150 watt amp running to them. Doesn't sound that great. But I'm not sure what model they are. |
Gold Member Username: RovinTrinidad & T... Post Number: 1152 Registered: Jul-05 | Well tell me how the cones look cause i remember how a few models look & then we can figure it out Is the cone silver plastic like & has diamond metal x patterns on it ? or dust cap appear to be made of carbon fiber ? or an uplifted 3 spiked pattern on it ? U should look around Pioneer's site or other website & post back a link - then we go from there but i think most Pioneer 12s are 350/400wrms ... |
Alex K. Unregistered guest | Heres an image. GO to http://www.geocities.com/sixer2007/sub.jpg |
Gold Member Username: RovinTrinidad & T... Post Number: 1156 Registered: Jul-05 | "Is the cone silver plastic like & has diamond metal x patterns on it ?" - i was right on it with my ist guess too ! from memory - that sub is old , over 3yrs for sure . Will take some time to track that online but 350wrms is my guess ......... i'm searching for it .. |
Alex K. Unregistered guest | Alright thanks. I really appriciate it. |
Alex K. Unregistered guest | Bump |
