New member Username: Tushmen36Post Number: 2 Registered: Oct-05 | I have a 500/1 JL amp, I recently purchased 2 10" subs in a bandpass box. can I somehow split the amp line and hook it up to both subs. please help starting to get frustrated LOL |
Silver Member Username: TdbdadrummerPost Number: 445 Registered: Aug-05 | Yes yes, wire the external terminals in parallel to them amp. |
Silver Member Username: TdisantoPost Number: 363 Registered: Sep-05 | http://www.the12volt.com/caraudio/woofer_configurations.asp |
Silver Member Username: TdbdadrummerPost Number: 446 Registered: Aug-05 | Ok mr. hyperlink! I was just going on what he told me. Note that he didn't leave any information, like how they are wired internally, whether they are SVC or DVC, or 2 or 4 ohm! |
Silver Member Username: TdisantoPost Number: 367 Registered: Sep-05 | WTF is your problem Tyler. I was just helping the guy. I know he didnt offer much info, so i posted the link because it offers the info he needs. Do you have a problem with me? |
New member Username: Tushmen36Post Number: 4 Registered: Oct-05 | The hookup I had before for a single dual voice coil 4 ohm kicker amp. i did not do that work, but was just wondering since I had a hookup if there is an easy way to split it that maybe i could do myself. The new subs came pre wired for 4 ohm operation |
Silver Member Username: TdbdadrummerPost Number: 449 Registered: Aug-05 | I'm just messin' around a little sheesh! I just tend to be a little sarcastic at times... |
