What new sub to get?
Username: Armedforglory
FL U.S.
my buddy has a Ford F-150 Standard cab truck. He had an old RF sub in a box behind his seat on a 100Wx4 amp. what would be the ideal subwoofer for his amp? he wants something that has good punch to it, but also something that will give some great bass!
also, could I have an explanation on how to hook up whatever sub you suggest?
thanks for all the help guys!
Username: Robert_d
MIA, FL USA
Post Number: 187
what is the amp model and name
also is that 100rms or 100 max watts
if its 100rmsx4 u can get 2x RE RE subs (comes in 8-12") and just bridge the amp so it gives 200 rms to each sub
Username: Robert_d
MIA, FL USA
Post Number: 188
also they go from
8" - 49$
10" - 59$
12" - 69$
do you serve in the military ?
FL U.S.
Post Number: 7
its a Jensen POS...lol
its a jensen a4000, puts out 4x100 that is what is written on the side of the amp..i dont know whether its rms or peak...anyone know about old jensen amps? i'll research it, and try to find out..
also, never had this clearly explained to me, what is bridging? and how is that wired up?
no, i dont serve in the military..its a church thing.. :-)
FL U.S.
Post Number: 8
http://cgi.benl.ebay.be/AMPLI-JENSEN-A4000_W0QQitemZ4577415181QQcategoryZ14264QQ cmdZViewItem
anyone know german or whatever it is?
FL U.S.
Post Number: 9
ok, i cant find any specs on it that aren't in a foreign language, and i dont see many numbers on those pages...new idea
what setup, amp and sub, should he get?
he is lookin to spend around or less than $225, and is lookin for good solid bass, but doesnt need earth-shaking bass..
