POLK MMC6500 vs Infinity Kappa Perfect components
Username: Sinx85
Post Number: 47
hey guys whats better in SQ and overall.
POLK MMC6500 or infinity kappa perfect
thankx
Username: Tdisanto
Post Number: 343
I like the Polk tweeter better than the infinity, so IMO i would do polk. Plus i like the grills they come with :-)
Username: Goon
Post Number: 343
Does the Polk do a metal tweeter or a silk dome?
Mike, why do you like the Polk tweeter better than the perfects?
Username: Tdisanto
Post Number: 352
the Polk is a silk Polymer composite. I liked it better just because its softer. I have the db690s but the MMC6500s use the same tweeter.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 859
I have the MMC6500 in stock loactions which is pretty high up on the door. I put the tweeter in the corner of the dash next to the apillar and windshield. They sound awesome with 90w.
About 6 months ago I had Perfects in stock loactions which was low in the door, and I was giving them 100w. They sounded good, but not as good as the Polks.
I also agree with Mike on the tweets.
Username: Langless28
Post Number: 296
i have both sets in my jeep and the kappa tweeters do sound a little high but once they break in, they sound golden.
Username: Sinx85
Post Number: 54
mmmm bassfishing can you please tell me how do infinity tweeters break in. Mine are very harsh :-(
thankx
Username: Sinx85
Post Number: 55
guys how are these speakers CDT Audio EF-61. Are they at the same level as infinity perfects and polk mmc6500 Or better ?
which one you ll buy if they are all at the same price ?
thankyou
