Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 210 Registered: Sep-05 | OH MAN MY TRUNK WONT STOP RATTLEING PAST 23/40 how do i get rid of the rattle:S? Dynamat and what ever best place to buy it please? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 211 Registered: Sep-05 | USING MY VIBE 248 at 2ohms pushing 500RMS WOOOW |
Anonymous | sucks to be you.... |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 213 Registered: Sep-05 | How do i stop that rattleing:S??? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12657 SOmthing like that for my Civic TRUNK ANY ONE PLEASE and THANK YOU! |
Gold Member Username: Kd7nfrMontpelier, ID United States Post Number: 1026 Registered: Apr-05 | Dynamat it. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 217 Registered: Sep-05 | LInk to a great online buy plz? |
Bronze Member Username: CoreyPost Number: 25 Registered: Aug-05 | I have the perfect site. (www.google.com) eDead it |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 224 Registered: Sep-05 | thanks for the name its actually google.ca around here but thanks mr.genius. Hate it when people act smarter then they are i ask for a link to a STORE for a great buy and u gave me a name and google thanks:S If any one else knows or has bought from some where b4 that was a great buy plz let me know thanks. |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2139 Registered: Aug-05 | the cheapest place to buy dynamat is on ebay. and for the most for you money, buy the bulk pack. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 227 Registered: Sep-05 | 20sq foot? or 40sq foot? How much would i need for my civic trunk and do i gota put it on the trunk door or all around in trunk would be best? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 228 Registered: Sep-05 | also now would you reccomend a bigger battery? or a capacitor because the lights start to dim alot. |
Bronze Member Username: CoreyPost Number: 26 Registered: Aug-05 | I say edead would be a cheaper alternative to dynamat http://edesignaudio.com/category.php?type=damp but if you want to use dynamat, you would cover the entire trunk with it. Sorry about that other post, I was a little irritated about something. |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2141 Registered: Aug-05 | put it in both places. to solve this problem, you will need a HO Alternator and a new battery. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 229 Registered: Sep-05 | alright the HOLE TRUNK? I only have rattle from the trunk door tho. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 230 Registered: Sep-05 | Well i guess for now ill go with a bigger battery 1000RMS isnt big enough load to demand a bigger alternator isit? Would it screw it up for the long run? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 231 Registered: Sep-05 | Muddy is this okay bro??http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D5775421195&ssPageName= STRK:MEWA:IT |
Bronze Member Username: CoreyPost Number: 29 Registered: Aug-05 | If your lights are severly diming, you WILL NEED a HO alternator esp. with a 1kw amp. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 232 Registered: Sep-05 | its just minor the inside light dims just a tad on a hard hit base note only when the car is at a stand still. Plus at night time it wont be playing this hard no way i dont want to draw to much attention. |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2144 Registered: Aug-05 | i had a 300wRMS amp in my car and my lights dimmed. lol so i got an HO alt........problem solved. now i have TONS of headroom for upgrades in the future.(some of which i have already done) btw, your link isn't working for me. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 233 Registered: Sep-05 | ebay links never work bro ima try it aagain. http://cgi.ebay.com/40Sq-Ft-eDead-Sound-Deadening-67-Off-Retail_W0QQitemZ5775421 195QQcategoryZ67760QQssPageNameZWD1VQQrdZ1QQcmdZViewItem if that doesnt work www.ebay.com search edead and scroll down to the buy now section at 35$ 40sq. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 234 Registered: Sep-05 | dont think i want to spend money on a HO if lights dim slightley maybe bigger battery for winter start ups and thats about it unless HO going to damanage anything else |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2147 Registered: Aug-05 | i have heard Edead works really good, but some people complain of its smell and lack of "stickiness" but i would definitely go for it. it will dramatically reduce the vibrations. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 238 Registered: Sep-05 | the one from the link??????? |
Silver Member Username: ThigpenRVA, Va Usa Post Number: 137 Registered: Sep-05 | im looking at some HO alternators for when i put my 2 SE's and componets which i havent determined yet in my car, how big of an alternator will i need, and how much will it cost. i talked to another guy who put a 200amp alternator i believe in his 3000Gt like mine and said it cost him 600$.. do i need one that big and will it cost me that much? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 239 Registered: Sep-05 | http://cgi.ebay.com/40Sq-FteDeadSoundDeadening67-OffRetail_W0QQitemZ5775421195QQ categoryZ67760QQssPageNameZWD1VQQrdZ1QQcmdZViewItem ?? |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2160 Registered: Aug-05 | yeah, that should be more than enough. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 240 Registered: Sep-05 | nICE nicee well ill get that then thanks bro. Now how id get that installad and stuff would be somfing id want to know how to do would i need to tape the ends just to make shore or what? |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2167 Registered: Aug-05 | they should provide you with a roller tool, which gives it a nice "grab" to the surface you are applying it to. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 241 Registered: Sep-05 | shuld i take a picture or somfin and show u what im going to have to attach it 2 for u to get a better feel of what im doing n if it iwll work :S? or it will work regardless? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 242 Registered: Sep-05 | Oh and on my HU i turned the base down from +12 too +2 because that was gettting hectic ill prolly turn it back up after i get the dynamat but i dont wana over do it what so ever will the band pass box hurt my subs in any way:S? |
