Looking for advice before doing something stupid
Username: Fightinchunk
Atlanta, GA US
Post Number: 8
Hey all
i have a piece sony sawm500 sub that i got about 3 months ago and am looking for a new sub. This one is already blown and was looking at a velodyne dps 12. I found one for about 360 dollars, but was looking at what other people would spend thier hard earned dollars on. i was looking at a velodyne dls 3500r but don't really know much about it. Any advice/suggestions would be very helpfull thanks.
Username: Devils_advocate
Post Number: 498
Try looking at HSU at www.hsuresearch.com or SVS and www.svsubwoofers.com.
Username: Edster922
Post Number: 2518
I'd get the Hsu STF-2 in that price category, $400 new or $320 refurb from them direct. Outstanding value!
Username: Infamous
HAS ANYONE EVER HEARD OF RE SUBS???
Username: Edster922
Post Number: 2523
sure dude, RE subs are like, the coolest thing since mayo in squeezable plastic bottles...
Username: Infamous
I was thinking about getting one but i didnt know much about them
Username: Edster922
Post Number: 2541
get the Hsu instead, much better.
Atlanta, GA US
Post Number: 9
does the digital whatever in the velodyne make it any better than a hsu sub that doesn't have that fancy crap? all im interested is something that will give me pure bass and shake the crap outta me. so if the HSU will do it better than the velodyne dps12 even though the hsu doens't have that digital crap, then i'm def goin for the hsu.
Atlanta, GA US
Post Number: 10
ok, so i have it down to the velodyne dps12 and the hsu stf2. both are 200 watts rms, and the velodyne has a 12 inch woofer compared to the 10 incher on the hsu. so what makes the hsu a better buy than the velodyne? keep in mind that i can get the velodyne for about 20 bucks more than i can get the hsu.
btw, is there a chance i can listen to the hsu at all? any retailers out there?
