How can I connect home theatre with old TV?
Username: Slniecko
I've bought SONY DAV D150 but I have very old television. I'm not able to connect it and watch DVD or TV. Only way how can I connect it is use coax because of old TV. I cannot set required channel 36 on TV because of TV. TV has about 20 years :-), but it works very well so I dont want buy new one at least 1/2 year, but I want fully use my home theatre system (jpg, VHS, DVD). Now I can only listen it.
Username: Samijubal
Post Number: 1692
You need an RF modulator. You won't get near the picture quality that the DVD player is capable of using the RF input. You should consider buying a new TV if you can afford it.
Username: Slniecko
thanks,
I know I should buy a new TV, maybe at Xmas, but I wanted test my home system. I know there can be problem with expected and real impedance of TV, but that's all I know about it.
