4x6" components
Username: Robert_d
MIA, FL USA
Post Number: 195
ive decided to go with kappas for 80$ shipped
would anyone choose another brand instead?
i dont want the oval shaped, the kappas come on a rectangle plate with a 4" mid speaker and a tweet above it
im not to sure about this built in cross over they have but is that the same as an external crossover?
lol and glass i was on google lookin up reviews i found your 22 post about these sayin there really good =)
Username: Tdisanto
Post Number: 368
lol, ive searched for stuff too and its brought up stuff from here that were posts glass had answered. I wonder what his very first post said.
The SQ with the plate will be better than a 4*6 oval. However you will lack a lot of midbass with the 4" compared to a 6.5". It wont transistion with the subs quite as well. But if thats all you can fit than i think theyre a good choice
Username: Robert_d
MIA, FL USA
Post Number: 196
also there 2 ohms and its gunna be run off of a head unit not an amp ... arnt head units 4 ohm ? will this work ?
Username: Robert_d
MIA, FL USA
Post Number: 197
yea thats all i can fit thats the bad thing =(
Username: Riebread77
Post Number: 675
get the .5i series instead of the .7i series...the .5i series is 4 ohms
Username: Robert_d
MIA, FL USA
Post Number: 210
yep thanks found them
