720p and 1080i
Username: Tehipwn
I plan on buying an HDTV, probably around 34" CRT, for using as a computer monitor and playing Xbox360. The Xbox360 supports 720p and 1080i. If you were to have 2 HDTVs side-by-side running from the exact same source...let's say an Xbox 360 racing game, so that means the on-screen action would be fast paced. Would there be a noticeable difference in resolution clarity and framerate?
I know 1080i has a higher resolution but sacrifices framerate. So which one is preferable and why? Also, are there even any CRT non-projection models that support 720p output?
