WHich one should i do...i am leaning towards tubed and using 3 inch PVC pipe... Does anyone know which is easier to install? And if you have used PVC before what did u use to support it and where is ur port located.
slot ports are easier to build into the box. and round ports can give off port noise and but they both sound the same i would recommend a slot port box.
