How do you define distortion
im trying to set my input level on my amp and i know you turn your HU 3/4 the way up then slowly turn up gain until you hear distortion, but what do you define as distortion, like what would having the gain all the way up do?
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1148
really, you're likely to reach distortion before you actually hear it. it helps to have signals on the amp that indicate it is clipping your signals.
it also helps to have a song that you know well. that is, you know what the bass is supposed to sound like. your subs should reproduce this bass effortlessly. when it starts to break up and sound loud but noisy, you have been clipping for a while. this is why i tend to send extra powewr to my subs so i have the head room to back off and still establish good power with a accurate and powerful low end presence.
however, if you have bum subs, you will potentially be distorting bass before the amp distorts the signal. thus, it could make it increasingly difficult to distinguish such a point.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10655
Distortion
Unwanted change in an audio signal that results in the presence of frequencies in the outpu signal that were not present in the original signal. There are sseveral types of distortion, however the two most common types are known as harmonic distortion and intermodulation distortion. In addition to the "garbage" traditionally known as distortion, all amplifiers generate a certain amount of noise (this can be heard as a background "hiss" when no music is playing). More on these later.
ALL amplifiers alter input signals, generally in two ways: they make them stronger (amplify them), and they add characteristics which did not exist in the original signal. These undesirable characteristics are lumped together and called distortion. Noise can be considered a type of distortion and was discussed in the above section.
Everyone is familiar with gross distortion, the sound quality that results when turning up a radio or boom box to "full blast". An excessive amount of amplifier clipping (see section below) results in hideous distortion that would be totally unsatisfactory for a sound system. However, not all distortion is blatant. In addition, there are several types, two of which will be discussed. Knowing what causes distortion will help you to prevent it from occurring. Knowing how to control distortion is important because excessive distortion can be detrimental to speaker systems (and your reputation).
Harmonic distortion: One common type of distortion is harmonic distortion. Harmonics of a signal are signals which are related to the original (or fundamental) by an integer (non decimal) number. A pure tone signal has no harmonics; it consists of only one single frequency. If 100 Hz pure tone signal was applied to the input of an amplifier, we would (upon measurement with special test equipment) find that the output signal of the amplifier was no longer pure. Careful measurements would likely show that several "new" frequencies have appeared. These new frequencies are almost certain to be integer multiples of the original tone; they are the harmonics of the original signal. In the case of a 100 Hz input tone, we might expect to find tones at 200, 300, 400, 500 (etc.) Hz. We would also probably notice that the odd harmonics are much stronger than the even harmonics (we will not go into the reasons why in this article). In a good amplifier, the harmonics will be much weaker than the original tone. By much weaker, we mean on the order of a thousand times for decent amplifiers.
All amplifiers are generally rated for Total Harmonic Distortion (or THD), usually at full power output over a given frequency band with a particular load. Good values are anything less than 0.5% THD. When an amplifier is measured for THD, a pure tone is applied to the input and the output is measured with special test equipment. The energy of the pure tone is measured, and the energy of the harmonics is measured. Those two values are compared, and a THD rating is calculated. A THD rating of 1% means that the total energy of all the harmonics combined is one one-hundredth of the energy in the fundamental.
Harmonic distortion (although certainly undesirable) is one of the more tolerable types of distortion as long as it is kept reasonably low. Distortion levels of 10% may be very tolerable with music so long as the 10% level is only "occasional." (10% THD on a pure tone can easily be heard by the human ear... but who listens to pure tones?) The reason that a seemingly high value of THD is acceptable for music is partially because many sounds in nature are rich in harmonics. Also, most decent cassette decks (which most people agree sound pretty good) have THD (off the tape that is) of several percent. Worse, even good speakers can have THD up to 10%, especially at low frequencies! All in all, the human ear can tolerate a fair amount of THD before it becomes objectionable.
Do two amplifiers with identical THD ratings sound the same, everything else being equal? Not necessarily (but differences will be subtle). The reason is that the THD specification states nothing about where the harmonics are in the frequency band. For example one amplifier could have a dominant harmonic at one frequency and a second amplifier could have a dominant harmonic at a very different frequency. Or, one amplifier could have a few "big" harmonics while a second has many weak ones. These situations could easily result in identical THD ratings. The variations could be easily measured with laboratory equipment. However do not be overly concerned. Minor variations in THD ratings will not cause major differences in sound when listening to music. With pure tones as input signals it might be fairly easy to discern which of two amplifiers was used (but again, who listens to tones?)
Intermodulation distortion: Intermodulation distortion is the second "major" type of distortion that is often specified for amplifiers. Intermodulation distortion is much more objectionable to the human ear because it generates non-harmonically related "extra" signals which were not present in the original. It is analogous to someone singing way off key in a choral group
Intermodulation distortion (sometimes abbreviated IM) is more complicated to test for and specify. Basically, two pure tones are simultaneously applied to the input of the amplifier. If the amplifier were perfect, the two tones (and only the two tones)would be present at the amplifier output. In the real world, the amplifier would have some harmonic distortion (as described above), but careful observation of the output signal (using laboratory equipment) would reveal that there are a number of new tones present which cannot be accounted for as a result of harmonic distortion. These "new" tones are called "beat products" or "sum and difference" frequencies, and are a result of the interaction of the two pure tones within the amplifier. No amplifier is perfect, all have some non linear characteristics. Whenever two signals are applied to a nonlinear system, new signals (in addition to the original two) are generated. For a good amplifier, the new signals are very small in relation to the two original tones. This is fortunate, since the ear can detect much lower levels of intermodulation distortion as compared to harmonic distortion.
It should be noted that distortion measurements on amplifiers are made with test tones. These tones are usually sine waves (pure tones), which represent the simplest possible test signal to measure and quantify. A music signal is an extremely complicated waveform consisting of many constantly changing sine waves. Since music has so many harmonics and frequencies present, quantifying how two different amplifiers will sound by using simple THD and IM specifications is extremely difficult. In other words, just because two amplifiers have the same published specs for THD and IM does not mean that they are equivalent. Fully and completely quantifying the technical performance of an amplifier would be extremely complicated and costly (and would probably have little benefit in the end). Most amplifiers available today (from reputable manufacturers) have THD and IM levels low enough to yield excellent performance (so long as they are not overdriven). This leads nicely into our next topic...
Clipping: What is this?
Clipping is a term which many people have probably heard, but may not fully understand. Very simply, clipping of an amplifier occurs when one tries to get a larger output signal out of an amplifier than it was designed to provide.
As stated before, all power amplifiers have a DC power supply which provides power to (among other things) the output stage of the amplifier. For most amplifiers, the power supply consists of a "plus" supply and a "minus" supply. The two voltages are often referred to as "rail voltages" or simply "rails". As an example, a 200 watt per channel amplifier (at 4 ohms) might have a power supply voltage (rails) of +/- 120 volts DC. This means that the output voltage which drives the speaker can never exceed + 120 or - 120 volts. If the amplifier is playing at near full volume, and someone cranks up the volume, the amplifier will attempt to put out more power. However, the power required to meet the sudden new demand for more volume cannot be met by the power supply voltage, which has limits of +/-120 volts in this example. The result is a waveform with the top portion (or peak) "clipped" off (hence the term "clipping"). Such clipping represents a distortion which is added to the waveform (and if it is severe enough it will be clearly audible). If a signal is severely clipped, the waveform takes on the shape of a "square wave", and the resulting sound will be absolutely hideous. Clipping can be easily observed using an oscilloscope attached to the amplifier output.
Clipping is not usually a major problem for amplifiers (unless it is extreme), but it can be very detrimental to speakers. Whenever clipping occurs, two things happen: (1) the spectral content of the music signal is altered (high frequency components are generated), and (2) signal compression occurs. If excessive clipping occurs, tweeters will be the first to blow followed by midrange drivers. Woofers are best equipped to survive clipping (unless the abuse is blatant or the subs are poorly designed.)
In general, clipping of an amplifier should be avoided. Use an amplifier that has clipping indicators, and pay attention to them! Occasional clipping is OK and probably not very audible. However if you find yourself clipping the amp most of the time, you should consider obtaining a stronger (or additional) amplifier.
