Deciding between two amps. Help please
Username: Jeze
Post Number: 43
I'm upgrading my amp and i'm having a hard time choosing what I want to upgrade to.
I currently have Boss Riot RT1500 which I swear is not really spitting out 800 watts at 2 ohms. I know, they post the max as their RMS.
I'm thinking of upgrading to either:
SoundStorm Force Amplifier - F2500D
# Class D Digital Mono Subwoofer Amp
# 2500W x 1 Max at 2 Ohms
# 900W x 1 RMS at 4 Ohms
# 1500W x 1 RMS at 2 Ohms
# S/N Ratio: 102dB
# Low Pass Crossover: 40Hz - 150Hz
# High Pass Crossover: 200Hz
# Bass Boost: 0 - 18dB
# Frequency Response: 9Hz - 50kHz
# THD @ RMS Output: 0.01%
# Channel Separation: 90dB
# Damping Factor: 125+
# Variable Input Level Control
# Remote Subwoofer Level Control
# High & Low Level Inputs
# High & Low Pass Crossovers
# Dimensions: 11"(w) x 2-3/8"(h) x 12-1/2"(l)
(OR)
# RMS Power: 900W x 1 @ 4 Ohms
# THD at 4-Ohm RMS Power: 0.05 %
# RMS Power: 1500W x 1 @ 2 Ohms
# Speaker Level Inputs: No
# Preamp Outputs: Yes
# Built-In Crossovers: LP
# Bass Boost: 0 - 18 dB
# Frequency Response: 50-300 Hz
# Signal to Noise Ratio: >100 dB
My subs will are wired at 2 Ohms. I currently have x2 Audiobahn AW1206T's.
Username: Jeze
Post Number: 44
Cardomain is being stingy with the specs of the Boss Amp btw.
Username: Jeze
Post Number: 45
Sorry the amp after the (OR) is a Boss Riot 2500D
Username: Rovin
Trinidad & T...
Post Number: 1109
U are pretty much taking 1 step up , 2 steps back - lol
Both companies are big liars about their ratings .
SAve $ & then buy like a Kicker ,RF, Orion , JBL
or if u really can't spend much try Hifonics amps
Username: Robert_d
MIA, FL USA
Post Number: 163
really there horrible companies
go with kicker mtx rockford amps ... those are popular companies which make good amps
if u can afford jl or orion go with them
if u can afford any of those hifonics is pretty decent for the money but there overrated so ull have to get a higher rms amplifier than you would of regularly gotten im not sure but there around 26% overrated ... does that sound right people ?
Username: Rovin
Trinidad & T...
Post Number: 1112
YEP ! - its been said numerous times by actual users . lol
Another option is to go search ebay for the better brands i mentioned .......
Username: Jeze
Post Number: 46
Thanks for the replies. Any opinions on MA audio amps?
Username: Rovin
Trinidad & T...
Post Number: 1117
same low quality bracket as above
Username: James_g
TN
Post Number: 287
Orion is actually just as cheap, or cheaper, than the Kicker amps. The 1200D generally sells for less than the KX1200.1. They certainly aren't as expensive as JL amps.
