Bronze Member Username: Terry6405Sullivan, IN US Post Number: 25 Registered: Sep-05 | if an amp says it runs 500watts x 2 RMS at 2 ohms, does that mean two ohms per sub or 2 ohms overall is there a diagram that shows this |
Gold Member Username: CarguyPost Number: 4515 Registered: Nov-04 | That means each sub gets 500w. Try www.bcae1.com. |
Bronze Member Username: Terry6405Sullivan, IN US Post Number: 26 Registered: Sep-05 | yea but what is th idependance on each sub |
Gold Member Username: CarguyPost Number: 4516 Registered: Nov-04 | 2 ohms. |
Bronze Member Username: Terry6405Sullivan, IN US Post Number: 27 Registered: Sep-05 | ok so if i wired 2 type-r's(1242D) at 2ohms each to an amp like that they would get 500 RMS each? |
Gold Member Username: CarguyPost Number: 4534 Registered: Nov-04 | Correct, assuming you supply 2ohms to each channel. |
