Allvoer Unregistered guest | Okay 2 questions: 1)Does the fader cause distortion? 2)Will fading my front components and playing at high volume cause it damage? Thank you for ur time |
Silver Member Username: TheelfkeeperStockbridge, GA USA Post Number: 433 Registered: Feb-05 | http://www.bcae1.com/ theres an explanation and demo under the head unit section |
Allvoer Unregistered guest | Thanks for the link man.. but there's little info about the fader function there So all the fader does is alter the signal? What happens to the power going to the speakers? Hmmm.. so in a way does it work like an Equalizer, Cutting and boosting? |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1988 Registered: Aug-05 | no, it simly fades the signal going to that speaker. it doesn't add any power, but it does in a sense, take away power. |
