Silver Member Username: FandimReno, Nevada United State... Post Number: 251 Registered: Jun-05 | Ok, here's the story of a man named brady.. No for real, heh heh. I was wondering about custom-making the inputs for my amplifier... But I wanted to know.. I wanted to use 8 gauge speaker wire, however, my amp only accepts up to I think 12 gauge for speaker wire.. It's a mono amp, and has two inputs... Also, my amp is in a spot where there's not too much extra room, and the connection might be stressed a little on occassion.. (Dont forsee this happening, but I like to make 100% sure none of my connections will come lose, come hell or high water) So I want to solder the original connection, and use a distribution block (with the connection going to the amp soldered, as well). Would there be any problem in doing this? ![]() Assuming the two inputs were 12ga, and the output was 8ga? (keeping the 12GA wiring to less than 3".) Any problems with this? |
Silver Member Username: FandimReno, Nevada United State... Post Number: 252 Registered: Jun-05 | Also, my inputs are extremely close together...This would also provide some room to work with... |
Gold Member Username: CarguyPost Number: 4544 Registered: Nov-04 | What kind of inputs do you have? Isn't it RCA? Why would you want to upgrade to 8 gauge? For is your goal? |
Silver Member Username: FandimReno, Nevada United State... Post Number: 257 Registered: Jun-05 | Isaac, I'm referring to the speaker wire terminals, not RCA's. ![]() |
Gold Member Username: CarguyPost Number: 4555 Registered: Nov-04 | So you trying to upgrade the output stage of your amp? Unless you're talking about 2000w rms, there is no difference between 12 gauge and 8 gauge. The voltage and current flowing is just too low to take advantage of thicker wires. Think about your household applications. The voltage is 115v and 15A max. Look at the wires used. It's nothing close to 2 gauge or even 0 gauge wires. |
Silver Member Username: FandimReno, Nevada United State... Post Number: 260 Registered: Jun-05 | Isaac, amp is rated at 1600 RMS.. And It's a pretty good length of wire, which is why I wanted to upgrade the size. ![]() |
Gold Member Username: CarguyPost Number: 4560 Registered: Nov-04 | I see, well 12 gauge is still good. I guarantee you using 8 gauge won't make any difference to your ears. The reason is, there is no high currents flowing, just volts. |
Silver Member Username: TdisantoPost Number: 203 Registered: Sep-05 | Isaac is right, 8 guage is overkill especially for your system (1600 watts RMS). Glass feels the same http://www.wickedcases.com/caraudio/wire.html |
Silver Member Username: FandimReno, Nevada United State... Post Number: 261 Registered: Jun-05 | Ok, well, regardless, would there be any disadvantages to doing this? I'm not particularly fond of the inputs on my hifonics, and, to use the least amount of wire, I'd need to run three inputs direct from the amp, instead of chaining from the terminals of the boxes.. The 8 gauge isnt necessarily entirely about performance, either.. but also for aesthetical reasons.. Fits the look of the setup more. But even without that - the hifonics terminals simply will not safely hold three 12 gauge connections.. (right now, I have them hooked up, but it's very..sketchy. Trimed down about half of two of the wires to fit them both in the same terminal, etc.) So again... Would the idea of using like a distribution block for my speaker wire have any negative consequences? ![]() Seth |
Gold Member Username: CarguyPost Number: 4567 Registered: Nov-04 | Not really, as long as you do it properly, it can't harm anything. |
