Bronze Member Username: 78elcaminomanDallas, Texas United States Post Number: 52 Registered: Jul-05 | what would be the best pair of 6 by 9's for the buck, all comments are accepted thanks |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1871 Registered: Aug-05 | imo, some DLS 6x9's. http://www.dlsamerica.com/speakers/964.htm |
Bronze Member Username: 78elcaminomanDallas, Texas United States Post Number: 53 Registered: Jul-05 | are they any good, |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1872 Registered: Aug-05 | incredible. but they aren't cheap. they probably retail close to $300-$400. not sure on the price though. |
Bronze Member Username: 78elcaminomanDallas, Texas United States Post Number: 54 Registered: Jul-05 | a pair or a piece |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1873 Registered: Aug-05 | you should look at some JL coaxials, or perhaps some infinity's. they sound very good also, and you don't have to spend that much on a set of speakers for them to sound good. i just got off of DLS's website and came over here, so that's why i recommended them. lol |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1874 Registered: Aug-05 | a pair.(both speakers) |
Anonymous | Kappa 6x9s 110 rms |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 84 Registered: Jan-05 | infinitys are real good for the price! |
Silver Member Username: Riebread77Post Number: 666 Registered: Jun-05 | i wouldn't spend $300-$400 on 6x9's...if your going to spend that much...get a 6x9 to 6.5" adapater and get some good component speakers...you will be much happier...if your only going to spend up to $150, then i'd go with 6x9s |
Silver Member Username: Riebread77Post Number: 667 Registered: Jun-05 | look in cdt...they make a 6x9 component system for not too much |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1919 Registered: Aug-05 | me either. just giving suggestions. |
