My 15"s
Username: Mindgame
i got 2 15" kicker L7s (2ohm) and 2 hifonics 1500d, with the kicker 0/1 pkd1 (dual amp kit).
i drive a ford expedition and i think the alternator puts out something like 130-140amps and i was just going to buy 2 caps till i get the money for a new alternator. whats good :D
Username: Scubasteve
College Park, MD
Post Number: 575
whats good is patience, saving money, and not throwing it away on gimmicks that will do nothing for you before you get your alternator, and less afterwards.
Username: Audiobass10
Cape Coral, FL United States
Post Number: 222
In other words, forget the caps and save up for a H.O. alternator.
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 291
how much r the h.o. alt.
Username: Basshead86
Ocala, FL USA
Post Number: 1797
depends on the amount of Amps you want and the vehicle and mounting options.
Ocala, FL USA
Post Number: 1798
Amps = Amperes like as in 250A just so there was no confusion
Username: James_g
TN
Post Number: 270
You're looking at approximately 2000w "true" RMS just for your sub amps. You're gonna need an alternator....
Like Steve said, patience is a must in this hobby. Never rush into purchases without doing your homework.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 977
yeah and i highly doubt ur car has a 130-140A stock alternator... my escalade has a 130 and thats extremely large... idk if any1s ever seen how many electrical things are in an escalade.... makes installation really hard...so yea 1 HO alternator is probably just a tad more than 2 caps.... be patient my friend.
