so if i were to go for the compvr subs..which ones should i get. Kicker Comp VR 03CVR104 10" Dual 4-Ohm Voice Coil Component Sub 10" Component Subwoofers or Kicker Comp VR 03CVR102 10" Dual 2-Ohm Voice Coil Component Sub 10" Component Subwoofers..thx
ok so am I just stupid for wanting to have my subs work not as one but in Stereo? And in order to get a DVC 4 ohm 150rms per coil to run correct in stereo I'll need a 4ch 600W amp or just get the single cone subs and use a 2ch amp 600W amp. Or say screw the Stereo subs and get a mono 600W
dogeatdog
ok... one more thing. what kind of enclosure should i get. i want the bass to sound good, not just be really loud.
stereo separation stops around 250Hz, so there's no point to stereo subs as opposed to both being in mono. In fact, you want both in mono so they work completely together and move the same air at teh same time.. creating more bass.
as for the type of enclosure.. try a ported box tuned low, around 30-35Hz.
