New member Username: InsanemonkeyboyWarminster, Wiltshire England Post Number: 7 Registered: Sep-05 | Okay i have been looking around for the best 5-channel amp out there and i have found an amazing deal with free shipping. LOOK! http://www.cardomain.com/item/PHOR905 I've almost decided on this amp to power the following alpine speakers: SPR-69LP 6"x 9" (15 x 23cm) COAXIAL 2-WAY SPEAKER SPR-17LS 6-1/2" (16.5cm DIN) COMPONENT 2-WAY SPEAKER The sub is coming at a later date but it'll be a 12" Alpine Type R sub which is 300W RMS. I doubt the 15" is 400W or less, but if it is i might consider it for mind-blowing bass! Please anyone let me know if there is a better amp for me cause i know the Octane is a monster and i am not using all of the power it produces. Thanks! Jonny |
New member Username: InsanemonkeyboyWarminster, Wiltshire England Post Number: 8 Registered: Sep-05 | Final Spec: 1. Sub AMP = Alpine: MRD-M605 Mono Amplifier 2. Sub = Alpine SWR-1242D - R-Type Dual 4ohm Voice Coil Sub Woofer 3. Sub BOX = 12" Sealed HQ Box 4. Wiring = Complete 4G Amplifier Wiring Kit 5. 6x9's = SPR-69LP - 6"x 9" (15 x 23cm) COAXIAL 2-WAY SPEAKER 6. 6-2/1's = SPR-17LP - 6-1/2" (16.5cm DIN) COAXIAL 2-WAY SPEAKER 7. Front and Rear AMP = MRV-F345 4/3/2 CHANNEL POWER AMPLIFIER Total= £647.50 (Not Including Head Unit). This took some serious research but i'm hoping that price is good. £60 was saved due to a bundle here: http://digitalsounddirect.co.uk/shop/product/products_id/1891.html Cheers |
New member Username: InsanemonkeyboyWarminster, Wiltshire England Post Number: 9 Registered: Sep-05 | Oh yeah, All of the speakers are from the Alpine Type R Range if you didn't realise from the model names. (He boasts) |
Silver Member Username: Camaro823British Colu... Canada Post Number: 221 Registered: Jun-05 | If your looking at PG, try the xenon series of amps they are very good. You can get them real cheap and brand new from ebay or other online stores. The type R you have, is it the newer one (SWR-1242) ? if it is then its the 500w rms sub, just letting you know. |
