Bronze Member Username: Yuro25Post Number: 11 Registered: Sep-05 | Can soemoen please help me im new to this and i have no idea what amplifier i need for these subwoofers. Im willing to spend up to about 400 dollers on the amp. here are the specs for the subs Please help me! thanks to anyone 12" subwoofer with dual 4-ohm voice coils carbon fiber/aluminum honeycomb cone with high-roll Santoprene rubber surround cast aluminum frame frequency response: 23-200 Hz power range: 500-1,000 watts RMS (500 watts per coil) peak power handling: 3,000 watts sensitivity: 83 dB top-mount depth: 8-11/16" sealed box volume: 0.65-1.25 cubic feet ported box volume: 1.0-2.0 cubic feet |
Bronze Member Username: Yuro25Post Number: 12 Registered: Sep-05 | PLEASSSEEE HELP |
Silver Member Username: RovinTrinidad & T... Post Number: 916 Registered: Jul-05 | To get an amp powerful as that its more like double that $ . |
Silver Member Username: JoebruceKY U.S.A. Post Number: 237 Registered: May-04 | Rovin is right if you need that much power ur gonna be spendin alot more than $400.Try hifonics,mtx,or jbl they are good amps and there not to exspensive problly the "best bang for ur buck" |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 506 Registered: Jan-05 | idk mabey two mtx 801d amps that would be pushing the $400 budget and they would be underpowered by 300 watts. |
Silver Member Username: JoebruceKY U.S.A. Post Number: 240 Registered: May-04 | Find a 2ohm stable amp bridged that puts out like 800watts and wire the subs to get 2ohms and u will only need one amp. |
Silver Member Username: RovinTrinidad & T... Post Number: 917 Registered: Jul-05 | IT is (2) 12" type X - u are asking about right ? if so then this Hifonics but its underrated but within your budget http://sonicelectronix.com/item_3491.html |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1088 Registered: May-05 | https://www.ecoustics.com/electronics/forum/car-audio/163946.html the earthquake is on sale on ebay. |
