What are the possible reasons for a TV not switching on?
Username: The_oct0ber
I have a sanyo.My tv just won't turn on.What could be the possible reason?I'd appreciate if you guys can suggest a few thhings that I should look at to figure out the problem?
Username: Youzer
I'd start with checking the outlet to make sure it's plugged in. If so, then I'd check to see if the outlet is working. I'm sorry if that sounds too remedial, but that's what I'd do first.
fx
Hundreds of possibilities, I'll list a few:
1 Breaker blown in breaker box
2 Breaker blown on powerstrip
3 TV not plugged in at all
4 TV not plugged in properly
5 TV plugged into outlet with burnt wires
6 TV power switch bad
7 TV power supply bad
8 Remote batteries dead
9 Fuse blown in TV
10 Terrorism
xvxvxvx
Username: Youzer
LMAO...
Good list. I'd also have to inquire about whether or not this TV had been submerged in a liquid or dropped. Has it ever been hit with a shoe? or maybe a shotgun blast?
