New member Username: ChrispyPost Number: 1 Registered: Sep-05 | which amp should i get to power a single JL w3v2 D4??? i was told an alpine would be good, which which kind??? |
Silver Member Username: RovinTrinidad & T... Post Number: 859 Registered: Jul-05 | Thats a 10" sub right ? Dual 4 Ohm i½ 300W RMS then http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14927 |
Bronze Member Username: SpyderEglin AFB, Florida USA Post Number: 95 Registered: Jun-05 | i have used that amp before on a single 12 in a small sealed box in a Honda Civic....sounded pretty good....anouther amp you can pick up for about that price range is the Jl 250/1 or you can get the (e) series versions for a little cheaper. but the alpine should do you good.....check around ebay for a lower price as you might be able to get it for cheaper!! |
