2001 Toyota Tundra Speaker Sizes
Username: Gallop
Fredericton , New Brunswick Canada
Wondering what the sizes of the stock speakers are. Thanks for the help...
Brandonk17
http://www.crutchfield.com/cgi-bin/autoinfo/Speakers.asp
This is what crutchfield says will fit your truck if you are looking to replace your speakers. If you are just looking for the specs on them you should look in the manual and it would probably tell you what are the stock speaker specs.
Username: Tdisanto
Post Number: 129
Do you have the six speaker system upgrade or the regular 4 speaker system?
I think that link above is bad :-)
If you are going to replace put 6.5" components in the front for better imaging. Amp them too.
Username: Gallop
the six speaker system.. its a buds truck..
He was looking at some 6.5 Pioneer's that come with the crossovers and tweeters.
we are planing to amp them up.. also
Username: Gallop
the Pioneer speakers are the REV Series
Username: Tdisanto
Post Number: 131
I wouldnt go with the pioneers myself. Ive heard them personally and some people on this board have also had problems with the pioneer speakers as well. Pioneer makes really good decks, not so much good speakers.
But if your buddy likes them than thats all that matters.
If your talking about the TS-C160R, they go for about $160 or so. You could do Polk, Infinity, Eclipse for a bit more if you want to spend a little extra to get a little better.
Username: Gallop
Post Number: 7
yeh the Pionners are the TS-C160R's
I've been trying to tell him to get a set of Infinity, but he is not biting..
The Infinity is what I will be putting in my F-150
