Subsonic Filter
Username: Baseballsc
Post Number: 26
is it absoltely necessary to have a subsonic filter on an amp, if the box is tuned to around 26 hz???
Username: Invain
Michigan United States
Post Number: 3766
In need a subsonic filter (highpass filter) somewhere in the chain if your subs are in a ported box, yes.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1054
http://www.caraudio911.com/
look under "subsonic filter matters"
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10551
the filter is only needed if you're running an enclosure with a port, and you don't want the speakers to unload and destroy themselves.. otherwise, nah, no need for that.
ideally you'd use one even with a sealed box though set to 20Hz just to avoid wasting power producing notes you can't hear anyway
