how would this work since when the car is moving below a certain speed, it turns to electric...if that is so, how would it effect a hi wattage system in a car? I do not have plans on buying a hybrid and i don't have one now, but i was just curious
CARAUDIO
extra or bigger battery for shore and a better alternator.
If anything dont go over 1500watts RMS for shore. If you hit high way then you could crank up the power on your system.
