MEMPHIS speakers?
Username: Edster922
Post Number: 1876
I heard that their amps are excellent, but never heard anything about their speakers...
has anyone here?
Username: Soundstreamjeep
Hickory, NC U.S.A.
I hang out at the local shop and they sell a lot of memphis speakers, amps, subs, etc. The speakers are good I've heard them and they are very dependable.
brendanmemphis
i just bought 2 memphis 6x9 120 watt maxx 3 way iwas just woundering if they can handle a 50watts from an amp there the kind u can move the tweters around 180 degrees.
Hickory, NC U.S.A.
Post Number: 9
I'm not sure but u can look on the box u got them out of and it should tell you how much RMS they can handle.
Username: Tdisanto
Post Number: 128
Try www.google.com
or RTFM.
Your choice
My feeling is that they prolly will handle it no problem as long as you dont clip the amp. (Thats always a give in) But you should refer to my other two suggestions first just to make sure
brendanmemphis
ty
brendanmemphis
ty
