2 amps to 1 cap...
Username: Audio_paul
Watkins, MN United States
Post Number: 15
ok first i have 2 1800 watt amps and i need a cap i was wondering if i can hook up a 6 farad cap to both amps..
another problem might be i have 0 gauge wire and i seen alot of caps and theres no way i can fit 2 wires in the input can u help?
Username: Smhuosrktays
Rochester, New York USA
Post Number: 68
The way to fit more wires than it is supposed to have, is by using wire terminals.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 410
you can either use the cap as a distribution block to each amp or run a strand from the cap into a distribution block then to both amps.
