Switch KD-SX780 with alpine CDE-9841?
Nick_SQ
hey, i currently have a JVC kd-sx780 in my car right now. I am not at all happy with the volume it produces. It is pretty boomy down low but has little to no bass at higher volumes. It doesnt have a subwoofer control either. I just seen a good deal on a new alpine CDE-9841 and was wondering if anybody's had experience? My deck is 19Watts rms x4 the alpine is 16 watts RMS x4...both decks have 2.0V pre-outs. Alpine has sub control, mine does not. Mine is a flip down face with remote, alpine is not.
You can see im in a bind.....
Does the alpine bass center/frequency control do alot for the sound? Do you think it will be better then the JVC?
My set up is alpine type S coaxials in front stock 5x7's in the rear. I have an ORION cobalt 10" sub in a ported box with a pioneer amp (gm 300t) giving it 150 watts RMS....Go alpine or keep my unit?
Username: Illuminator
Post Number: 1777
The Alpine will definitely sound better.
One reason for the poor bass at high volume levels is that you might have 'Loudness' turned on?
