Fiberglass 2nd try
Username: Mrdark
Post Number: 125
check it out people!
http://i10.photobucket.com/albums/a145/urgeone/caraudio009.jpg
http://i10.photobucket.com/albums/a145/urgeone/caraudio010.jpg
http://i10.photobucket.com/albums/a145/urgeone/83a8a8d8.jpg
http://i10.photobucket.com/albums/a145/urgeone/61c8b87a.jpg
Username: Mrdark
Post Number: 126
btw, I did not want to post 2 threads! It asked if I wanted to cancel the first one, and I chose to, but it somehow still posted!?
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 384
Slick, and noone will even know whats inside... nice...this ones for the sleepers.
Username: Scubasteve
College Park, MD
Post Number: 568
man, you should invest in a plunge router and a circle jig. looks good though
Username: Mrdark
Post Number: 128
it was tough without the above tools mentioned that's for sure! but it'll still be worth it I hope! that is just my driver side, If I like it, Then I'm going for my passenger side also.
College Park, MD
Post Number: 576
did you fleece it yet matt? Anway, however it comes out, it'll be better than stock so you might as well go for it.
Username: Mrdark
Post Number: 130
ya, it's fleeced...problem now is should I mount it with screws to the doorframe and then put the trim over it, or keep it mounted on the trim? I ask this because it is hard to fit the trim over the wood, especially now that it is fleeced and resined..and taking the trim off is just as hard. I'll post more pics tho..So far I have only done the driveres side hehe.
College Park, MD
Post Number: 578
well I can't picture exactly what you mean, but from what I think is going on, this is what I'd do. Add a couple layers of fiberglass to the inside, that way you can sand down the outside where the fleece is as much as you need to make it fit. Now what you'll want to do is only screw it into the sheet metal of the door, not the plastic door panel that covers it. This will leave the stock apperance but could introduce vibrations. To combat this, either use silcon between the panel and the enclosure or for a less permanent solution, weatherstripping or deadener will work.
College Park, MD
Post Number: 579
wait, now that I look back on the pictures, I definately missed something...I thought it was going to fit behind a factory grill, but from your pics I can see that it won't. How do you plan to finish the surface and make a new grill?
Username: Mrdark
Post Number: 132
i plan to reuse the grill
College Park, MD
Post Number: 584
I'm not picturing it, but thats what pictures are for :-)
Username: Dozyproductions
San Diego, California United States
Post Number: 150
hey matt. Im looking to do a similar thing. What did you do for the very back portion of the pod? (very back where its really in the door) Is that just how it came? in my car you take out the speaker and BAM you have the window so i was thinking i have to build some wooden ring/frame and fleece it and then attach to the rest of the project.
Username: Mrdark
Post Number: 134
Dozy, are u talking about the most-inner depth? I just used a coffee can for a mold and fg'd around the can, then cut accordingly.
Post Number: 151
yeah that is what i was talknig about. And then after you took out the can you just added that mold to the rest of your mold by merely adding mat to connect the pieces?
Username: Mrdark
Post Number: 135
yesir!
and scuba steve, here are the pics with the grill:
http://i10.photobucket.com/albums/a145/urgeone/caraudiogrill1.jpg
http://i10.photobucket.com/albums/a145/urgeone/grill2.jpg
College Park, MD
Post Number: 600
oh I see, its lucky that you have a grill that fits over the speakers without having to flush mount them.
Username: Robert_d
MIA, FL USA
Post Number: 133
lol i recognize that car ... is it a 92-96 camry ??
Username: Mrdark
Post Number: 136
99 maxima
Username: Robert_d
MIA, FL USA
Post Number: 137
oh ... i feel dum :P j/k but it looks verrryy much like my car door like the shape and contours
Username: Mrdark
Post Number: 137
scuba steve, yes i am lucky! i hope my passenger side one turns out just as good if not better!
Robert-maybe nissan and toyota used the same factory for door interior? I'm curious to see the similarities!
