New member Username: Indian81Post Number: 2 Registered: Sep-05 | Before I buy a new light engine, can anyone here verify that I do indeed need it? Here are my Samsungs (HLN5065W) symptoms which started a few weeks back: When watching, the picture would stall for a few seconds and then come back Lately, the screen would go completely black after only a few minutes of watching. This happens when watching DVD's as well. The Color wheel is noisy and intermittent. It takes at least 30 seconds for the picture to come up upon turning on the set. |
Silver Member Username: FyiDallas, Texas Post Number: 264 Registered: May-05 | Since when did you feel you were qualified to diagnose DLP televisions? Since when did you start trusting BB for service. 1-800-SAMSUNG Prompts 2 then 1 then 3 then 1. |
Silver Member Username: Tombo777Post Number: 730 Registered: Jul-05 | Thats your former Texas Instrument employee giving you empathetic advice. BTW TI designed that crap they call DMD that requires that dumb color engine idea. I work for no one and can tell you you are screwed. That you can take to the bank. |
Silver Member Username: FyiDallas, Texas Post Number: 276 Registered: May-05 | Sounds like a lamp and a color wheel is all you need. Both are easy to replace. http://www.samsungparts.com |
Silver Member Username: Tombo777Post Number: 742 Registered: Jul-05 | Tell him how much and how long those parts are warranted TI boy!! |
Silver Member Username: FyiDallas, Texas Post Number: 295 Registered: May-05 | What difference does that make? |
Silver Member Username: Tombo777Post Number: 764 Registered: Jul-05 | I'll tell him..You have a 2160 hour reprieve...... Thats 90days of 24 hour watching. Enjoy. |
Silver Member Username: Tombo777Post Number: 765 Registered: Jul-05 | or just 90 days...Period. |
Silver Member Username: FyiDallas, Texas Post Number: 307 Registered: May-05 | You don't actually think you can make someone believe that the life of a product or service is equal to the warranty, do you? I got a 90 day warranty on my car repair. I'm confident that the parts and service will last well beyond 90 days. Who are you kidding? |
