Grounding my engine?
Would running extra wire from my alternators ground to chasis be considered a Engine -> ground wire?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10469
the alternator grounds through the engine which has a block-to-chassis ground line that should be upgraded.
the alternator itself doesn't ground directly to chassis.
Hmm... So wouldnt using the point at which the alternator grounds to the engine, and attaching a beefy wire, and running it to a secure chasis point, be similar to upgrading the vehicles engine to chasis?
Bump?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10490
the engine ground is used for more than just teh stereo.
do it the way I already said.
GlassWolf, could you tell me where my block-to-chasis ground is located at, on a 98 Camaro?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10517
not offhand, no. look in a haynes manual, a GM serviec manual, or on google.
it shouldn't be too hard to find.
