New member Username: LivinlifePost Number: 10 Registered: Sep-05 | I have a 94 pathfinder and people are suggesting to remove my H/U and then cutting the speaker wires from the harnass and connecting my 16 gauge speaker wires from there and then send to the back. or others are suggesting to just connect it through the speakers. the door panels are pretty easy but then i have speakers to the back thats in the roof! i mean stuck in the room and i only can remove it by popping out the grille and unscrewing the screws. Buttttttttttt... i dont want any wires hanging down the ceiling connected to my amp. its like when a booger is hanging.. it is not cute and professional. LOL. What do you guys all suggest??? |
Bronze Member Username: TdisantoPost Number: 90 Registered: Sep-05 | Assuming you have a stock HU without preouts.. This should solve your problems. http://www.crutchfield.com/S-4OaKeOAimdV/cgi-bin/ProdView.asp?g=721&I=142SLC4 |
Bronze Member Username: LivinlifePost Number: 11 Registered: Sep-05 | sup bro thanks for the response.. but i have an aftermarket H/u it only has one pre out though. im going to be using my 4channels output for my mono block amps RCAs. i just dont know how to install my speakers to my 4channel amp. |
Bronze Member Username: TdisantoPost Number: 92 Registered: Sep-05 | You just connect speaker wire from the speaker output of the amp to the speaker itself. |
