I've been going over many options as to what amp I should hook up to the Kicker 15" L7 Solo-Baric I am buying (1000W RMS/2000W Peak). The first amp I was going to get was the Kicker SX900.2, that would bridge to 900 watts RMS at 4 ohms. Then my uncle suggested the Kicker KX1200.1 which gives 1200 watts at 1-ohm. Since I really like the SX line of the Kicker amps, I got thinking about the SX1250.1 which gives 1250 watts at 1-ohm. My main problem in deciding is my lack of technical knowledge. I have no idea how the sub will work on the amp with the 4-ohm impedence vs. the amps with the 1-ohm impedence. How do the impedences of the amp and sub interact? Can someone please fill me in? Thanks for all the help
How about an amp with 800x2 at 2 OHM RMS and at 1 OHM is 2x1000 watts RMS...max 4000 watts. 4 OHM this amp runs at 2x500 watts RMS. Depends on what your willing to spend!
